What shutter speed should I aim for...
Postby owen on Sun Jun 04, 2006 9:44 pm
when attempting DIY studio portrait shots.
I bought some cheap floodlights from Bunnings today and was experimenting around but I found that even with my camera on a tripod, a shutter speed of 1/40 still resulted in quite soft photos. Despite me asking my patient model to remain as still as possible.
Should 1/40 be fast enough or should I be aiming at a quicker shutter speed?
Postby gstark on Sun Jun 04, 2006 10:54 pm
I'd be aiming for something around the 1/125 or 1/250 marj=k, unless you're looking to possibly capture some movement.
It might not matter if you go slower.
or it might. ;)
Postby owen on Sun Jun 04, 2006 11:38 pm
Thanks Gary. I'll do some more experimenting and see how the results turn out.
Owen.
Postby Yi-P on Mon Jun 05, 2006 12:15 am
1/500 can make black/dark backgrounds, slower gets more details...
Postby rmp on Mon Jun 05, 2006 9:35 am
I'd say 1/40 is too slow. Try 1/125 to be on the safe side. A slow shutter speed would result in a blurred image, not a soft one. There are soft-focus lenses for a special type of portrait look and the result is different to blur caused by a slow shutter speed.
Robert
rmp
Postby owen on Mon Jun 05, 2006 10:28 am
The reason why I said soft instead of blurred is because it is not an obvious movement blur, and the model was as still as possible. But now after seeing everyone's responses I'm almost certain it was due to slow shutter speed now.
Thanks for the suggestions everyone.
Postby Raskill on Mon Jun 05, 2006 11:26 am
Maybe it was the cheap lights from Bunnings that caused it? :lol:
http://www.awbphotos.com.au
Raskill
Postby Yi-P on Mon Jun 05, 2006 2:27 pm
They have photographic lightings at Bunnings?? :roll:
Postby owen on Mon Jun 05, 2006 2:38 pm
Yes indeed. Items mentioned above may or may not be a fire hazard - use at own risk :shock:
Postby rmp on Mon Jun 05, 2006 8:05 pm
Also bear in mind that the sharpness of many lenses varies over the aperture. It's worth taking a few shots at different apertures to determine where you'll get best results from the lens.
Robert
rmp
Postby owen on Mon Jun 05, 2006 11:16 pm
Yeah, I was using the 50mm 1.8 and I was shooting at apertures that I know to be really sharp.
Thanks.
