Epson R1800 - changing inks and clogging questions
Postby Hlop on Fri Jun 16, 2006 11:46 am
Hi,
I don't want to steal mic's R1800 tread, so, created new one
As recently discussed, I've got a set of Piezography K7 inks for Black and White printing and they are brilliant but I'm going to finish my B&W album pretty soon and that will be time to change cartridges to the native Epson colour inks. AFAIK, Epson "sucks" fair amount of inks to the head and if I'll change cartridges, initially it will be spraying out old inks from the previous set (B&W in my case!). I've heard some gossips about "flushing" inks from the head but don't know how it should be done properly. Any suggestions?
Second question. Sometimes I don't print anything for a month or two. Famous Epson's head clogging and drying problem - has it been fixed? Or shall I still print something at least once per week? How do you keep your nice R1800s away from such problems?
Mikhail
Hlop
Postby smac on Fri Jun 16, 2006 12:17 pm
Mikhail,
Some good advice can be found at the following site:
http://www.colorbat.com/clearingnozzles.htm
Stuart
'Tis better to have loved and lust than never to have lust at all.
smac
Postby Matt. K on Fri Jun 16, 2006 1:09 pm
Mikhail
I have read somewhere that flushing windex through the heads will clean them out when you change back to colour. Otherwise it's going to cost you a fortune. You can prevent clogging by not leaving the printer turned on for long periods of time unless it is printing. Apparently, when you turn the printer off the head is parked and the jets are sealed to prevent drying. Use your printer at least once every month. Avoid cheap paper. It can flake and clog your heads. Pro printers brush each sheet with a soft brush before feeding it through to remove dust and other particles.
Postby Hlop on Fri Jun 16, 2006 3:06 pm
Thanks for your help, guys!
Matt, please forgive my ignorance - what "windex" is?
Mikhail
Hlop
Postby NikonUser on Fri Jun 16, 2006 4:20 pm
Hlop wrote:Thanks for your help, guys!
Windex is a type (brand?) of window cleaner
Paul
NikonUser
Postby Hlop on Fri Jun 16, 2006 4:29 pm
Paul
Wow! :shock: I'm sure I don't want to put something like this to my brand new R1800 :shock: :shock: :shock:
Mikhail
Hlop
Postby big pix on Fri Jun 16, 2006 5:47 pm
lots of info here on Epsons........
http://www.inkjetart.com/forum/index.php
happy for the comments, but
big pix
Postby gstark on Fri Jun 16, 2006 7:26 pm
Paul
Mikhail,
Grab a copy of "My Big Fat Greek Wedding" from the video store. All will become clear.
Pun intended. :)
Postby NikonUser on Fri Jun 16, 2006 7:46 pm
Paul
Mikhail,
Pun intended. :)
THAT MOVIE IS NOT FUNNY.... IT'S MY LIFE!!! :roll:
Paul
NikonUser
Postby joet on Fri Jun 16, 2006 8:15 pm
I have to second NikonUser .... I've been living that bloody Greek Wedding for over 44 years :violin: :agree:
Joe
joet
500 posts - only 6 years to go
Location: 2/163 Booker Bay Rd, Booker Bay, NSW Nikon D70, D300
Postby antman on Fri Jun 16, 2006 8:22 pm
NikonUser wrote:THAT MOVIE IS NOT FUNNY.... IT'S MY LIFE!!! :roll:
Paul
Are you a single 30 something greek chic ?
Geoff C
My Gallery:http://geoffc.smugmug.com/
antman
Postby NikonUser on Fri Jun 16, 2006 8:26 pm
Paul
:) Just after I hit the submit button I realised I was going to get a reply like that :)
As for the cleaning:
I've also read heaps (but never had to use) about using Windex or hot water. Apparently there are several differnt types of cleaing methods (some that can use up to 40% of an ink tank apparently) available to the higher end printers. Dunno if the R1800 has these...
NikonUser
Postby Hlop on Mon Jun 19, 2006 9:49 am
OK. Despite all the puns and jokes .... :D :D :D
... everything went much smother than I expected. Removed NK7 cartridges, installed UltraChrome ones, one cycle of head cleaning, printed a test pattern, printed a test photo - everything is just fine :)
Mikhail
Hlop
Postby Matt. K on Tue Jun 20, 2006 6:59 pm
Mikhail
That's excellent news! Shows how thorough the Epson cleaning cycle works! Also....the window cleaner is mostly water with a touch of metho and can be safely used to 'clean' inkjets'. It is also safe to use for cleaning a dirty printer by spraying a sheet of A4 paper and feeding it through. It gets ink off the rollers.
Postby DaveB on Tue Jun 20, 2006 9:11 pm
Matt. K wrote:the window cleaner is mostly water with a touch of metho and can be safely used to 'clean' inkjets'. It is also safe to use for cleaning a dirty printer by spraying a sheet of A4 paper and feeding it through. It gets ink off the rollers.
Be aware that cleaners with ammonia are NOT recommended for this sort of use. The corrosion will catch up with you sooner or later...
DaveB
