backward step?
backward step?
Postby DavidR on Mon Nov 12, 2007 12:36 pm
im currently waiting on my new DSLR body as im upgrading from my trusty d70s and was wondering why with the new(er) dslrs flash sync is restricted to say 1/250 while i can get 1/500 from my sq-a and sync at any shutter speed with the d70s. is this a shutter issue, ie do the better shutters restrict flash sync? any thoughts people!
nikon d300, 10.5mm f2.8, 17-50mm f2.8, 50-150mm f2.8. Bronica sq-a 80mm f2.8,. sunpak 383's and a 622 for kicks, pw's, and other assorted bag fillers
DavidR
Postby sheepie on Mon Nov 12, 2007 12:44 pm
The D70 actually has a combination shutter - both mechanical and digital. The 'higher-end' cameras (ie: D200 up) only have the mechanical, thus limiting maximum speed of the synchronisation (anything higher than 1/250th and the blades of the shutter obscure part of the frame).
At least, that's my understanding :)
sheepie
Postby Reschsmooth on Mon Nov 12, 2007 12:50 pm
The SQ-A has a leaf shutter which doesn't exhibit the same problems as the focal plane shutter which travels across the face of the film/sensor, hence the ability to synch to all shutter speeds up to the max speed of 1/500th.
Our mug is smug
Re: backward step?
Postby gstark on Mon Nov 12, 2007 1:03 pm
DavidR wrote:im currently waiting on my new DSLR body as im upgrading from my trusty d70s and was wondering why with the new(er) dslrs flash sync is restricted to say 1/250 while i can get 1/500 from my sq-a and sync at any shutter speed with the d70s. is this a shutter issue, ie do the better shutters restrict flash sync? any thoughts people!
This isn;t quite a simple question, as you're mentioning a number of different cameras, and they each employ dfferent technologies.
Let's start with the SQ-A - and I'll include the ETR-S, 'Blads, Rolleis, and most MF and LF cameras in this category. These cameras generally employ a leaf shutter, which is (usually) embedded within the lens. These sorts of lenses open from the center towards the outside, and then close towards the center again, often remaining closed until the camera is recocked.
Because they open from the center, the emulsion/sensor is fully exposed to the whole of the subject matter while the shutter has been opened, and thus the flash is able to be synched with the camera at all speeds that the shutter is capable of achieving. But the physical aspects of what the shutter needs to do in order to close, then open, then close again cause a restriction on the maximum speeds the shutter can achieve, and thus your 1/500 is not only the maximum sync speed, it's also the maximum shutter speed.
Typical SLRs, digital or otherwise, use a focal plane shutter. This uses a pair of curtains that travel across the focal plane. The first curtain opens the shutter, and the second curtain closes it. At some (very fast) speeds the distance (time) between these two events is very short, and this provides for a moving slit traveling across the focal plane.
As the shutter speed slows, this distance (time) increases, to a point where the slit no longer exists, and the shutter is fully open for some period of time, before the second curtain closes the shutter.
For correct flash sync, the maximum time will be the minimum time where the shutter is fully open. Anything faster will cause a dark band to appear on the image, being a shadow from the curtains that are not yet fully open, or which have already started to close.
Many older cameras (Canon A1/AV1/AE1 etc, Olympus OM series) employed a horizontal shutter movement. This means that the shutter traveled across the focal plane, which is a greater distance than a vertical movement required. Hence those camera had a sync speed of 1/60, while others had 1/125, and some employed titanium to achieve 1/250.
The D200 fits into this category of camera.
Other cameras take advantage of other technologies to achieve faster sync speeds: The D70 has an electronic shutter built into the sensor. This requires the camera to fully open the mechanical shutter, and then the electronic shutter actually makes the exposure. Being electronic, this doesn't rely on physical movement, and therefore faster speeds are able to be achieved. Because just one flash pulse is made, full power flash is able to be used with this method.
An alternative method uses the computing power in the camera to calculate the locations of the shutter curtains as they traverse the focal plane, and it fires multiple flashes as the shutter's slit travels across that focal plane, only firing the second (and subsequent) pulses when it reaches a point not yet exposed, and so on.
This obviously requires that the flash intensity be degraded to compensate for the pulsing it will be doing in order to make an exposure.
HTH.
Postby DavidR on Mon Nov 12, 2007 2:24 pm
thanks gstark, i was aware of the shutter setup in the bronica but you have filled in some blanks with the slrs! still its annoying they cant sort out faster sync speeds with slrs. ah well. more incentive to break out the film! :D
DavidR
Postby jamesw on Mon Nov 12, 2007 2:33 pm
DavidR wrote:thanks gstark, i was aware of the shutter setup in the bronica but you have filled in some blanks with the slrs! still its annoying they cant sort out faster sync speeds with slrs. ah well. more incentive to break out the film! :D
we're a minority dave, thats why they havent bothered to push flash sync much further.
there are some ways to get around the flash sync thing... sometimes it is pretty frustrating shooting at 1/250th, especially when you know how good 1/500th is...
so yeah dont rush to sell your d70s...
lens:nikon 35-70mm f2.8, 70-300mm f4-5.6, 10.5mm f2.8, 20mm f2.8, 28mm f2.8, 50mm f1.8.
flash: nikon sb600, sunpak 383 (x1), sunpak 555 (x4), pocketwizard plus II (x4)
jamesdwade.com
dishonourclothing.com
jamesw
