IPad 2 Down load speed?
Postby inmotion on Wed Jan 04, 2012 4:50 pm
Hi I am considering an Ipad 2 as a demo unit for customers can any one give me a clue as to its jpeg download speed for say 3mb file size 500 pics approx
cheers jim--Seemed very slow at a chrissie party loading straight from my D3s??
inmotion
Re: IPad 2 Down load speed?
Postby Remorhaz on Wed Jan 04, 2012 8:02 pm
Download in what way?
From iTunes to the iPad (via USB, WiFi, etc)
Via the web to the iPad (via Safari web browser)
Via eyefi over WiFi to the iPad
or ???
Postby biggerry on Wed Jan 04, 2012 8:09 pm
I was thinking more along the lines of transfer via cosmic radiation, that way there would be no interference and super fast.
did I think that or type that? :)
Postby ATJ on Wed Jan 04, 2012 8:42 pm
inmotion wrote:Seemed very slow at a chrissie party loading straight from my D3s??
I guess he means via the camera connection kit.
Postby inmotion on Wed Jan 04, 2012 11:18 pm
Cosmic Radiation HMMMMM must be Sydney humour :biglaugh:
down loading of Jpeg images from camera or from my base 1TB hard drive
My point is they seem easy to use and look great but is it slow to load pics from say a wedding to do a viewing?
:cheers: Jim
inmotion
Postby Remorhaz on Thu Jan 05, 2012 8:24 am
I don't think you can plug a hard drive into the kit. The "USB" interface via the kit is designed only to recognise camera memory cards or cameras I believe.
I have an iPad2 and the camera connection kit (which I've never used) so I could try it out for you if you like - the speed may depend however on the speed of the memory card and/or camera.
Postby inmotion on Thu Jan 05, 2012 9:52 pm
HI Thats more the info i need
as the Ipad 2 will not be in my primary chain of processing images then it sounds like a fair task to transfer images from Hard drive ti Ipad for a demo--
I was going to consider this to carry previous event pics with me (at a reduced size)
but there are some hidden traps
cheers jim
inmotion
Postby team piggy on Fri Jan 06, 2012 1:16 am
Camera connector won't power hard drives and some more hungry thumb drives.
Sent from my iPad using Tapatalk
D3 | D700 | D300 x 2 | D200 X 2| D70s| 300 2.8VR| 70-200, 2.8VR| 28-70, 2.8|24-70 2.8 | 14-24 2.8 | 50-500| 50, 1.4| 18-200VR| 10.5 Fishy | Batt Grips| SB800 x2 | SB900 |Pocketwizards | Manfrotto's blah blah.
team piggy
Postby Mr Darcy on Fri Jan 06, 2012 6:09 am
team piggy wrote:Camera connector won't power hard drives and some more hungry thumb drives.
If this is the whole reason, then surely a powered drive, or even a powered hub should fix the issue.
But I have a PVR with USB port that has all sorts of restrictions built into the firmware. Makes it pretty much useless for any real world application. Apple may have gone down the same path.
team piggy wrote:Sent from my iPad using Tapatalk
Marketing speak. Apple cares. We don't
Postby gstark on Fri Jan 06, 2012 8:05 am
No. They've crippled the connector; it's not a true USB host, so all bets are off.
Actually, that's a Tapatalk message.
Jim,
I'd probably be looking at a laptop of some sort for this. You can tether to the camera, and images will appear on the monitor in a matter of a second or two.
You could use an iPad as an external monitor if you wish.
And Lenovo have a USB powered extension monitor that could be passed around, but it requires a PC to drive it.
Postby inmotion on Mon Jan 09, 2012 9:33 pm
Thanks Gary and the others I have a macbook 13" so maybe this will do
cheers jim
inmotion
Postby Matt. K on Wed Jan 11, 2012 10:38 am
Downloading images using the optional Apple camera flashcard kit is painless and pretty quick. The Ipad is excellent for showing off digital images.
