Nikon camera rubber cover panel pealing off....Glue recomme
Postby haring on Mon Jan 09, 2017 5:29 am
My Nikon dslr camera rubber cover panel is pealing off.... It happened to me the same with my old Nikon. It seems to be a permanent problem with Nikon cameras. Do you have any glue recommendation? The glue needs to be flexible enough and keep the rubber panel on the metal housing of the camera....
Thanks so much!
haring
Re: Nikon camera rubber cover panel pealing off....Glue reco
Postby gstark on Mon Jan 09, 2017 6:38 am
In my experience, the consensus seems to be that, although it's a simple problem, there's no readily available adhesive that can rectify this issue.
Take it a local repair shop.
Postby biggerry on Mon Jan 09, 2017 10:44 am
http://blog.avernus.com.au/cemedine-super-x-no-8008/
this is the stuff specified in the Nikon Repair manuals. Otherwise a good wetsuit material adhesive also works well. If you were in Sydney i would lend you my tube of super-x :)
Postby Matt. K on Wed Jan 11, 2017 1:25 pm
Pop rivetts?
Postby ozimax on Sat Jan 14, 2017 8:41 am
Switch to Canon? :biglaugh: :biglaugh:
Postby biggerry on Sun Jan 15, 2017 9:34 pm
ozimax wrote:Switch to Canon? :biglaugh: :biglaugh:
yeah he will need some kind of acceptable dynamic range tho ;) :biglaugh:
