First try at Macro
First try at Macro
Postby sully on Wed Sep 01, 2010 10:32 pm
Here are my first shots at macro photography, it's great fun, and I think this will take up a fair bit of my time for a while as it's great fun...
some of you might notice the blue tinge above, I only realised afterwards that I shot this with the computer screen behind the flower :oops: oh well, these were really just 'playing with the new toy shots', next time...
Any guesses as to the flower?
sully
Re: First try at Macro
Postby surenj on Wed Sep 01, 2010 10:57 pm
Hi Sully,
No idea about the flower.. but I am sure someone will identify it!
This looks slightly fuzzy on my screen. :idea: Could I suggest that you use even higher apertures like f22 etc next time to increase your DOF. You may want to try manual focus as well.
I didn't know that the 24 105 could focus close like this.
Keep em coming. :cheers:
Postby sully on Wed Sep 01, 2010 11:04 pm
Hehe magic tricks :) (a macro filter that goes on the end of the lens - about $30. not bad for a bit of fun) they are a bit blurry, particularly the second... but it was my first try! I do know the flower, I work with them, just curious as to whether anyone else knows them... How is the composition etc?
sully
Postby aim54x on Thu Sep 02, 2010 10:10 am
Not bad for a $30 filter....now try to borrow a proper macro lens (Tamron 90mm, Canon 100L) and compare :twisted:
Postby gstark on Thu Sep 02, 2010 10:20 am
For a first effort: excellent.
And yes, a lot of fun.
What aperture were these shot at? Do you know where the sweet spot of lens is?
As Cameron has suggested, something like the Tamron 90mm might be an excellent choice for you: it's inexpensive, and bloody good.
Also, perhaps look into getting some extension tubes. Again, an inexpensive option, but a great way to get you learn and shoot more.
Postby Mr Darcy on Thu Sep 02, 2010 11:45 am
I'll vote for a Protea of some kind. Possibly the king.
A very good first attempt. but stop down more if you can. Use a flash to add more light if you need it. This will give you greater depth of field. Also put the camera on a tripod if you haven't already.
I second the suggestion of Tubes. This can be as simple as a toilet roll sticky-taped between the camera and lens, but I recommend the Kenko tubes for greater ease of use. You can also place one lens, reversed, in front of another to give you some amazing magnification. The results you get will depend on the lenses. Some combinations are brilliant, some don't work at all. Suck 'em and see.
Postby pennylane1284 on Thu Sep 02, 2010 1:59 pm
I agree with all of the people here. It's a pretty good first attempt, but I think that you can make your focus a bit sharper.
Reason: Removed unauthorised (spamming/SEO) signature line
pennylane1284
Postby sully on Thu Sep 02, 2010 6:57 pm
aim54x wrote:Not bad for a $30 filter....now try to borrow a proper macro lens (Tamron 90mm, Canon 100L) and compare :twisted:
But if I do that, i'll want to buy one!
Mr Darcy wrote:I'll vote for a Protea of some kind. Possibly the king.
Close, but no cigar... The King has a huge flower, if you cup your hands together in a bowl shape, that's how big they are, roughly (if you have big hands). This is a Leucodendron, part of the same family as Proteas but quite different in a lot of ways. this flower is about 2 inches wide.
I have extension tubes, but hate using them because I cannot change the aperature with them as they contain no circuitry. A toilet roll certainly does not have this function!
gstark wrote:For a first effort: excellent.
These were shot at f9 and f11 respectively, I will try a few different options when I have some time later tonight
Thanks all for the feedback :)
Josh
sully
Postby aim54x on Thu Sep 02, 2010 8:58 pm
I know.... :twisted:
Mr Darcy wrote:I second the suggestion of Tubes. This can be as simple as a toilet roll sticky-taped between the camera and lens, but I recommend the Kenko tubes for greater ease of use. You can also place one lens, reversed, in front of another to give you some amazing magnification. The results you get will depend on the lenses. Some combinations are brilliant, some don't work at all. Suck 'em and see.
The Kenko tubes fix this problem...they have circuitry to allow for aperture control and even AF (not 100% on IS, but I suspect so as well)
Postby gstark on Thu Sep 02, 2010 11:41 pm
aim54x wrote: and even AF
But for macro photography, AF is probably less important, verging on unnecessary.
Postby Mr Darcy on Fri Sep 03, 2010 12:19 pm
sully wrote:I have extension tubes, but hate using them because I cannot change the aperature with them as they contain no circuitry. A toilet roll certainly does not have this function!
Yes they also preserve IS (well VR anyway. who can say with Canon :twisted: ) But like AF, there is not really any point with macro photography.
You didn't mention you had manual tubes. If there is no connection, they work on minimum aperture. You probably want to be there anyway (or close to it!) in order to get maximum Depth of Field. You probably want really bright continuous light though so you can focus successfully.
Postby aim54x on Fri Sep 03, 2010 11:34 pm
Mr Darcy wrote:Yes they also preserve IS (well VR anyway. who can say with Canon :twisted: ) But like AF, there is not really any point with macro photography.
My thoughts exactly about the "IS". AF and IS/VR is not great for macro, but people ask for it (I will get at least one person a week complaining that AF in a macro lens is not fast enough - when used for macro, and at least someone saying "AWESOME" to IS/VR on the 100L (which is meant to be usable with IS as a macro) and 105VR (which is not recommended to use with VR)).
Postby sully on Sat Sep 04, 2010 1:34 pm
I am suprised, I thought they would stay wide open, as a lens would be before you take a photo so as to let maximum light through the viewfinder. How does this change with and extension tube?
sully
Postby aim54x on Sat Sep 04, 2010 10:40 pm
I think your correct Sully (for Canon lenses), but Greg is a Nikon user (like myself) and by default, the Nikkor lenses without aperture rings (G lenses) have their apertures in the closed down state until you install it on the camera body.
Postby zafra52 on Sun Sep 05, 2010 2:47 pm
Number one is the winner here.
Postby sully on Wed Sep 08, 2010 11:24 am
aim54x wrote:I think your correct Sully (for Canon lenses), but Greg is a Nikon user (like myself) and by default, the Nikkor lenses without aperture rings (G lenses) have their apertures in the closed down state until you install it on the camera body.
If anyone is interested, I have found a solution for canon lenses, fire up the camera with the lens installed normally, select your desired aperature, hold down the DOF preview button while removing the lens and the aperature will stay in that position until installed next time, so you can now reverse your canon lens, or use manual extension rings.
Josh
sully
Postby aim54x on Wed Sep 08, 2010 3:17 pm
Josh
Thanks Josh I will try to remember that one
